Activity › Forums › Avid Media Composer › Sapphire DeFlicker in Symphony?
Posted by Ernest Savage on November 15, 2013 at 11:37 pmAny tips in making Sapphire DeFlicker actually affect a clip? If tried setting the point, and moving the square, but I get only minor results.
Ernest Savage replied 12 years, 9 months ago 2 Members · 4 Replies -
John Pale
November 16, 2013 at 1:34 amI’ve had much better results with the BCC filter that does the same thing. You got it free with symphony.
Ernest Savage
November 16, 2013 at 6:03 amSome how this symphony doesn’t have BCC. I found a work around. I simply removed the frames with the higher luminance causing the flicker, and timewarped the clip to match the motion and timing of the original. Looks good. Thanks for the BCC tip. I’ll try when I can BCC again.
John Pale
November 16, 2013 at 2:32 pmYou are entitled to the BCC suite (Boris continuum). It’s a separate install. You can download it from Avid’s website.
Glad it worked out.
Note that both the sapphire and BCC flicker fix filters have several modes to try to remove the flicker, so you need to play with it a bit and use their help/manuals, as the controls are not that obvious. I’ve always had better luck with BCC than Sapphire for this, though the Sapphire filters are excellent in general, and mostly superior to the BCC.
