Saparate blend on a individual layer
Posted by Julio Crespo on July 26, 2006 at 12:30 amHoe I can separate the in-between shapes of a blended shapes on a individual layers, to use a cycling layer in invigorator
Image is Everyting
Julio Crespo replied 20 years, 1 month ago 2 Members · 6 Replies -
Jon Okerstrom
July 26, 2006 at 12:43 amIt depends on which version of Illustrator you’re using.
Try: Object>expand, followed by Object>ungroup.
Jon
Julio Crespo
July 26, 2006 at 2:29 amI use CS2 Version. I expand and ungroup but all the in-between shapes still on one single layer. I separate all shapes manually, but with this method is easy to make a mistake and the animation not correctly. anybody know a way to automatically make one layer for each in-between shapes…..sorry I a newbee in illustrator
Image is Everyting
Jon Okerstrom
July 26, 2006 at 3:27 amHi PRgraphist,
Check out the layers window and release to layers (sequence.) That should do it and save you a ton of time if you have a complicated blend going on.
Jon
Julio Crespo
July 26, 2006 at 5:42 pmOK,, This allow to separate all the items in sub-layers.. I need all the shapes in an layer itself not under other layer….
Thanks anyway….
Image is Everyting
Jon Okerstrom
July 26, 2006 at 6:13 pmSublayers do work as layer cyclying layers in Invigorator.
Jon
Julio Crespo
July 27, 2006 at 9:54 pmI try to open a cycling layer, but invig not “see” anything and do not give any error message or something like this just keep the scene as a empty scene
Image is Everyting
