Activity Forums Maxon Cinema 4D Sand or Dirt C4D
  • Sand or Dirt C4D
    Posted by Brad Borland on October 11, 2021 at 8:11 pm
    Does anyone have any idea on how to soften edges to make a pile of sand or dirt look more realistic? I created a landscape and made adjustments to look like the pile shape I want but it has a real hard edge. I would like to soften it up.
    Steve Bentley replied 4 years, 11 months ago 2 Members · 1 Reply
  • Steve Bentley
    October 14, 2021 at 3:33 am
    How has the “pile” been made?
    You could:
    -Put a very small noise on the pile and use a displacement (with SubD displacement in the material)
    -Make the pile a volume and use a volume shader on it to give it a bit more depth
    -Add sub surface scattering which would allow more light to penetrate through a little – sand grains are usually translucent so the top layer will let light pass and reflect back out.
    – do an xpresso and Thinking Particle sim to build a pile of sand (time consuming and memory intensive)
    – use a third party plug in to do a fluid simulation and then apply particles and geometry to the backed sim (sand is just a chunky stubborn fluid)
    – use a very small cell noise shader and put the noise in the reflectance channel. This will add sparkle and life to the sand – add this to the deformation idea above and it has promise!
    – populate a “hard” cone shaped object with thinking particles on the surface only and that will give you the little grains and you can have it “shift” with gravity or a pushapart on a voronoi fracture every once in a while to add life.
