Activity Forums Apple Final Cut Pro Legacy SAN reccomendations for FCP
  • SAN reccomendations for FCP
    Posted by Matt Ziegler on June 19, 2007 at 7:35 pm
    We are looking at switching away from Media100 to Final Cut as we move to HD.
    We are also looking at redoing our SAN network to handle the increased bandwitth of HD.
    We are looking at 3-4 seats on the SAN all running 1-2 FCP with DVCProHD and ProRes HD Streams. We want to move to a 4GB solution. Can the Cow Guru’s point me to a solid SAN solution?
    Any help is greatly apprecatied.
    Matt Ziegler
    IO Group
    Phillip Powell replied 19 years, 3 months ago 7 Members · 7 Replies
  • 7 Replies
  • Matt Gottshalk
    June 20, 2007 at 3:23 am
    I recommend Edit Share.
    https://www.editshare.com/
  • Phillip Powell
    June 20, 2007 at 2:31 pm
    …we talking here? Very interested for my facility, and would like to pitch to management,
    but some ball park cost range would help.
    Any idea?
    p2
  • Russell Lasson
    June 20, 2007 at 2:46 pm
    It really depends on your setup, but a 4 seed SAN could cost somewhere between $25-$35K. I went the ebay route and spend about $17, but ebay isn’t for everyone.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Sean Oneil
    June 20, 2007 at 3:33 pm
    I spent about $5k for an iSCSI SAN. It’s about 4TB, and there is dual-gigabit ethernet going to 4 seperate machines. MetaSAN software for 4 seats was another $4k. “Small-tree.com” sells dual channel ehternet cards.
    Sean
  • Walter Biscardi
    June 20, 2007 at 5:17 pm
    [mattziegler] “We are looking at 3-4 seats on the SAN all running 1-2 FCP with DVCProHD and ProRes HD Streams. We want to move to a 4GB solution. Can the Cow Guru’s point me to a solid SAN solution?”
    Facilis is one of the priciest but the absolute easiest to run. You only need a Fibre Channel card for each seat. No management software as the entire SAN is managed by the hard drive array itself.
    Ciprico makes very solid SAN solutions as well and I will be testing a ProMax solution probably next month with 2 units running off one of their Fibre arrays.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • David Jahns
    June 20, 2007 at 8:28 pm
    I asked this exact same question and got a lot of responses over at the SANetworks forum.
    Go check it out….
  • Phillip Powell
    June 22, 2007 at 5:03 am
    Just the input I was looking for.
    p3
