Activity Forums Apple OS X Samsung305T and MacBook Pro
  • Samsung305T and MacBook Pro
    Posted by Monica F.p.williams on August 14, 2016 at 10:50 pm
    Is there anyone that was able to connect a Samsung Syncmaster 305
    To a mac book pro?
    This Samsung is an older 30″ model with a DVI/D
    Input, I’m fine using it at lower resolution, attached to a USB port
    Is there any active connector DVI D to VGA? My other monitor is connected with a display link.
    I hav only 1 Thunderbolt and I need it for my external HD.
    Thank you.
    Monica
    Monica F.P.williams
    crocodile editing
    https://vimeo.com/crocodileediting
    web: http://www.crocodileediting.com
    The “EARTH” without “ART” is just “EH”
    MacBook Pro 17″
    Model Identifier: MacBookPro8,3
    Processor Name: Intel Core i7
    Processor Speed: 2.3 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 8 MB
    Memory: 8 GB
    Monica F.p.williams replied 10 years, 1 month ago 2 Members · 2 Replies
  • John Rofrano
    August 15, 2016 at 10:12 pm
    [Monica F.P.Williams] “Is there anyone that was able to connect a Samsung Syncmaster 305 To a mac book pro? This Samsung is an older 30″ model with a DVI/D Input”
    I connect my DVI/D display to my MacBook Pro with a Mini DisplayPort to DVI Adapter and it works great but it sounds like you already have that port in use. You could always get an OWC Thunderbolt 2 Dock if you need more ports.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Monica F.p.williams
    August 15, 2016 at 11:10 pm
    Thank you, you are correct I have only a thunderbolt
    Port, the mini display will also use a USB port
    :0( the OWC may be the only solution.
    Monica.
    Monica F.P.williams
    crocodile editing
    MacBook Pro 17″
    L3 Cache: 8 MB
    Memory: 8 GB
