Activity Forums Adobe After Effects Expressions sampleImage() disables multiprocessor rendering?
  • sampleImage() disables multiprocessor rendering?
    Posted by Bryan Woods on January 17, 2013 at 1:03 am
    WHY. WHY in the hell would you not allow sampleimage to utilize multi processor rendering?! Of all the effects, this would probably be one that would really benefit from this.
    Been using AE for over 10 years now, and I STILL don’t understand the logic of the developers. There just keeps being major oversights to this software that hold it back.
    That is all. Just a rant. >:(
    Xavier Gomez replied 13 years, 7 months ago 4 Members · 5 Replies
  • Darby Edelen
    January 17, 2013 at 4:05 am
    It’s obviously not that they’re trying to vex you and everyone else in the AE community, I’m sure there are technical challenges to implementing this.
    My workaround has always been to use Animation > Keyframe Assistant > Convert Expression To Keyframes on any of these expressions before my final render.
    Darby Edelen
  • Bryan Woods
    January 17, 2013 at 4:31 am
    But its such a pain to do that. It kills the dynamic usefulness of the expression.
    Would you happen to know of a way to convert the expression to keyframes, but only make one keyframe and not 1 for every frame? Because that ends up taking the most time when baking. I never need more than one keyframe usually when baking, and would probably speed things up greatly…
  • Kevin Camp
    January 18, 2013 at 5:04 pm
    [Bryan Woods] “Would you happen to know of a way to convert the expression to keyframes, but only make one keyframe and not 1 for every frame?”
    trim your layer to a single frame, convert the expression to keyframes, then set the endpoint back to the point it needs to be.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Xavier Gomez
    January 18, 2013 at 10:32 pm
    or memorize the value (!), disable the expression and write the value in the property value slot.
  • Xavier Gomez
    January 19, 2013 at 2:39 pm
    In fact all javascript-based features (so all expressions) can only use one thread, and they are also slower since they are interpreted on the fly. This has nothing to do with sampleImage itself.
