Activity Forums Adobe Audition Sample Rates and Bit Depth
  • Sample Rates and Bit Depth
    Posted by Jennifer Keller on October 15, 2014 at 8:37 pm
    I am trying to troubleshoot a problem in a multitrack session of Audition. The length of the file seems to change after exporting the session and the markers are all out of place when I bring it into After Effects.
    > Started with 2 – 32 bit, 480000 Hz files (worked fine upon export)
    > Added 5 – 16 bit, 414000 Hz files (time and markers are off after adding these)
    Is there a customary practice, when combining bit depths or sample rates? I am wondering if I am doing something wrong in this area?
    Chris Wright replied 11 years, 10 months ago 2 Members · 1 Reply
  • Chris Wright
    October 20, 2014 at 12:33 am
    did you try save as edit-convert sample to all match and edit-interpret each?
