Activity Forums Adobe After Effects Same/linked keyframes for a layer style across multiple layers
  • Same/linked keyframes for a layer style across multiple layers
    Posted by Marty Hoedjes on August 10, 2010 at 1:53 pm
    Hey guys,
    I’ve been trolling around the internet for an answer, but nothing seems to get it right. I got about 50 layer to which I assigned an Outer Glow effect. Now I want to change the opacity of this effect uniformly across all layers following a certain succesion of keyframes.
    But whenever I alt-click on the stopwatch and link the opacity to the keyframes, it only works for the one layer (though I have them all selected).
    Whenever I try to ‘Copy Expression Only’ and paste to all layers, the opacity changes over the entire layer, and I only want it to change for the Outer Glow.
    What can I do?
    Thank in advance,
    Marty
    Marty Hoedjes replied 16 years, 1 month ago 2 Members · 3 Replies
  • Dan Ebberts
    August 10, 2010 at 3:21 pm
    I just tried it, and Copy Expression Only works for me in your scenario. You have to have the property with the expression selected when you do the copy though – that’s the only thing I can think of. After you do the copy, paste it into a text editor. It should look like this:
    Adobe After Effects 8.0 Keyframe Data
    Layer Styles Outer Glow Opacity
    Expression Data
    thisComp.layer(“Layer 1”).layerStyle.outerGlow.opacity
    End of Expression Data
    End of Keyframe Data
    Dan
  • Marty Hoedjes
    August 10, 2010 at 3:27 pm
    But do I paste it for 50 separate layers then? That seems kind of redundant.
  • Marty Hoedjes
    August 10, 2010 at 3:33 pm
    Weirdly, it does seem to work OK now.
    I don’t know what I did wrong before, since the expression contains the information that the opcity is for Outer Glow.
