Activity Forums Maxon Cinema 4D Same size bump map for two separate materials
  • Same size bump map for two separate materials
    Posted by John Mcmullin on May 3, 2017 at 8:09 pm
    Hi everyone. Newbie here.
    This is probably a really easy question but I’m trying to create reflective, metallic text on a matte, textured paper. So I’d like the paper’s embossed texture to seamlessly move through the gold writing.
    So I made a bump map from the same image that is in the paper colour channel so that the bumps would line up properly with the image. I then made a thin text object, raised just a fraction above the paper. But when I chose the same bump reference image that was used for the paper it sizes the bumps completely differently.
    Thanks for any ideas.
    John
    John Mcmullin replied 9 years, 3 months ago 2 Members · 2 Replies
  • Cassius Marques
    May 3, 2017 at 9:22 pm
    If I understood you correctly its because your text object has a different uv than your paper, they translate differently into space.
    Go to your top view, select the material applied to the text, right click it and go to “fit to region” now do a rectangular marquee that matches your plane size.
    Cassius Marques
    http://www.zapfilmes.com
  • John Mcmullin
    May 4, 2017 at 9:36 am
    Many thanks Cassius,
    That did the trick. I’d kind of hacked it by changing the scale and offset, but that is the proper way to do it.
    John
