Activity Forums Maxon Cinema 4D Same scene rendering differently on Mac and PC
  • Same scene rendering differently on Mac and PC
    Posted by Didier Fereaux on November 21, 2018 at 2:35 pm
    I’ve got a scene which I’ve rendered both on my Mac and PC and they come out differently. The PC seems to over expose reflections and desaturate the colours a bit compared to my Mac. Same output, same settings, same display color profile. I literally copied the project file over and hit render.
    At first I thought it was a monitor profile issue, but when I copied the Mac rendered file over to my PC, it looked exactly the same as it did on my Mac.
    The reason I ask this is because I use an online render farm who use PC’s and when I send the file off to there, I get the PC looking output which is not what I want. I prefer the way the image looks on my Mac (hence why I export it from there and not work on it on my PC).
    Anyone else had similar issues?
    Justin Thomson replied 7 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Justin Thomson
    November 21, 2018 at 3:13 pm
    Not quite sure that a thing, can you post screen shots?
    When you get to the top, don’t forget to send the elevator down for the next guy
  • Brian Jones
    November 21, 2018 at 5:15 pm
    I agree with Justin, not usually a thing. It used to be a concern of Mac mixing with PC back when the chips were different but ever since the change to Intel by Mac I haven’t heard much. Steve or others might know more.
  • Didier Fereaux
    November 21, 2018 at 10:28 pm
    Hey guys!
    Here’s a screenshot comparison for one of the renders:
    https://i.imgur.com/m2LHnjt.jpg
    I’m using garagefarm.net. As you can see, the reflections are overexposed on the image on the right.
    I’ve done a bit of research and came across this forum thread:
    https://www.c4dcafe.com/ipb/forums/topic/46358-mac-vs-windows-differences-on-renders/
    “And it seems to be related with the image used to texture the Color Channel. This image is a PNG 6000×3000 pixels generated on my Mac using Photoshop.
    If I disable this image in the Color Channel, leaving it with a simple flat cream tone (and even leaving the rest of channels untouched: bump, specular and reflection with their greyscale textures controling that behaviours) then both renders on my Mac and the PC are absolutely identical when comparing on AfterEfects or Photoshop.
    The question now is, what can I do with all the Color Textures on my scenes when rendering on the PC? I need to prepare some custom texture versions only to render over PC’s? I suposse it’s something related to the Texture Image native Gamma and how it is exported from Photoshop on my Mac and how it is treated on the PC side when reading inside Cinema…”
    Maybe it’s something to do with the textures I’ve created in photoshop on my mac perhaps? Very odd.
    Don’t know if it’s anything to do with my computer specs but here they are anyways just incase:
    My Mac specs are:
    2012 Macbook Pro Retina
    2.7 GHz Intel Core i7
    16 GB 1600 MHz DDR3
    NVIDIA GeForce GT 650M 1024 MB
    Intel HD Graphics 4000 1536 MB
    My PC specs:
    Custom PC build
    Intel Core i7 8700K Hex Core LGA 1151-2 3.70GHz
    Corsair Vengeance Blue LED 64GB (4x 16GB) DDR4 3000MHz
    2 X EVGA GeForce GTX 1080 Ti SC Black Edition GAMING iCX 11GB
    View post on imgur.com
  • Didier Fereaux
    November 21, 2018 at 10:50 pm
    upon further reading it seems to be an .png issue when it comes to editing textures.
    I’m going to save them as a .tiff and let you guys know how I go! ☺
  • Didier Fereaux
    November 23, 2018 at 11:36 am
    no change. argh.
    I embedded the colour profile, didn’t embed, tried both. same results.
  • Brian Jones
    November 23, 2018 at 4:41 pm
    linear workflow comes to mind but since linear is a project setting and should be followed regardless of where you are rendering it doesn’t make sense (but my experience with rendering to different machines is limited)
  • Justin Thomson
    November 23, 2018 at 6:32 pm
    Must be the farm settings. Can you post the file, I work off PC.
