Activity Forums Storage & Archiving Same RAID, Same Mac, Two Different OS’s
  • Same RAID, Same Mac, Two Different OS’s
    Posted by Mike Browning on August 12, 2011 at 4:18 am
    Hi all,
    Been considering adding an SSD to my Mac Pro to run Lion, while keeping my current boot disk intact.
    My RAID was set-up with Disk Utility, so I assume it’s a software only RAID.
    My question is, will the RAID configuration be read-and-write-able on both boot disks? If, hypothetically, I want to work on a project in Lion, but then go back to my Snow Leopard drive to use some legacy software (not currently a need, just looking ahead), would I be able to do this with no problems?
    I’ve read that some folks lost their RAID when moving to a fresh install of Lion because their RAID was software-based. Their partitions were lost because it was created and read only on that particular boot disk.
    As a background note, I’ve never moved the RAID or tried to use it on a different set-up. I simply would like to know if my RAID configuration will stay intact before I go trying to use two different boot disks.
    Mike Browning
    Mike Browning replied 15 years, 1 month ago 2 Members · 2 Replies
  • Steve Modica
    August 12, 2011 at 12:02 pm
    most raid technologies store their setup data on the drive volume headers. The idea is that they can move elsewhere or even move to a new controller (of the same brand) and function.
    In my experience, some vendors intentionally don’t mount raids when they are moved to a new system because it’s assumed the volume may be shared. So you have to explicitly mount it the first time. (For example, you may have to tell Atto to automap the device).
    I don’t know about apple’s mechanism.
    Steve Modica
    CTO, Small Tree Communications
  • Mike Browning
    August 12, 2011 at 7:12 pm
    Thanks Steve.
    Many of my fears are articulated in this thread:
    https://forums.macrumors.com/archive/index.php/t-1192277.html
    I’d hate to boot up in Lion and discover my RAID partition has been destroyed. I also have a RAID 1 for Time Machine system backup. Wouldn’t be an absolute tragedy, but it would sure cost a lot of time.
    Anyone on the COW have experience with Lion and their RAID yet?
