Activity › Forums › Adobe After Effects › Same MPG file on two machines opens and not.
  • Same MPG file on two machines opens and not.
    Posted by Konstantin Davidenko on September 19, 2012 at 6:00 pm
    Hello!
    I have that kind of problem: i have some files, which can be normally opened from my old laptop, but, when i tried open them with new PC (with AE CS6) it trow error, that it can’t be opened.
    Why such thing can happened?
    Roland R. kahlenberg replied 14 years ago 4 Members · 15 Replies
  • 15 Replies
  • Tudor “ted” jelescu
    September 20, 2012 at 7:06 am
    It may have to do with the codecs installed on your machine. There are many MPEG flavors and you may need to install a more extensive codec pack on your newer machine.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Konstantin Davidenko
    September 20, 2012 at 9:03 am
    Thank you for your replay.
    I think I installed some codec packs on my machine. Can you advise me “more extensive codec pack”? Or, maybe, some of them…. It would be great!
  • Roland R. kahlenberg
    September 20, 2012 at 11:08 am
    Stick with common CODECs – Xvid stuff aren’t friendly with AE. You should let us know which CODECs are giving you issues.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
    September 20, 2012 at 12:14 pm
    https://codecguide.com/about_kl.htm
    Tudor “Ted” Jelescu
    Senior VFX Artist
    September 20, 2012 at 4:39 pm
    I don’t personally compress these videos. Here is some information about one of that kind of files:
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Duration : 51mn 23s
    Bit rate mode : Variable
    Bit rate : 4 100 Kbps
    Maximum bit rate : 6 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.395
    Stream size : 1.47 GiB (94%)
    It’s what you ask about? Or something else?
    September 20, 2012 at 4:40 pm
    I tried to install both “Mega” and “64-bit” packs, but still files in AE won’t work… =(
  • Thomas Leong
    September 20, 2012 at 4:56 pm
    The K-Lite Mega Pack also provides G-spot which will provide more info on the codec used in your media. If you can’t find G-Spot in the Start Menu > Programs, then look for it in the K-Lite folder under C:Program Files or Program File (x86).
    Once you know the codec used to encode your media, you can google for the codec.
    September 20, 2012 at 5:34 pm
    I can’t find any G-spot there, but there is “MediaInfo”. It returns that:
    Video
    Format : MPEG Video
    Duration : 51mn 23s
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    September 20, 2012 at 5:41 pm
    Did you restart your computer after installing the new CODECs? Further, the file is 52+ minutes which is kinda long for normal AE work. See if PPro or AME are able to ingest the file. If this is possible, either transcode the entire file to another CODEC (although storage requirements will be extremely high) or transcode just the part(s) that you need.
    HTH
    RoRK
    September 20, 2012 at 5:46 pm
    Ow… Thanks you! Yes, I restarted my PC few times. I’ve never done anything of what you told me to. I’ll try to google how to do that.
    Thanks you again!
