Same image Different resolution in AE en PS
Link to File : https://f1.creativecow.net/9999/exr-for-ae-en-photoshop#10000
Hey everyone, first of all i usually never post on forums. (I’m a hardcore reader). But i could not find any solution to this problem.
I have a rendered footage in openexr (exr) format. When i import this in AE or Premiere the resolution is 479 x 853.
It should be 480 x 854.The image is rendered in 480 x 854.
When i open this in photoshop the dimensions are correct => 480 x 854
So in AE en Premier its 1 pixel less from every side.
I will upload the image so you can see it your self.
PS: My workaround is to write a little script in photoshop which opens and saves the files. After doing this AE opens the files with the normal resolution, but i have so many files…i wish i could know what’s going on.
