Activity › Forums › Maxon Cinema 4D › Same Grass Problem
Same Grass Problem
Posted by Jason Stirret on July 27, 2012 at 11:31 pmI am running into the same grass issue as before and still have no solution. Determined to find a solution for this I am posting again. The link for the project file is attached, any advise or suggestions are highly welcomed!
4441_grass0007projectforthecow.zip
A special thanks to anyone who can help with this.
Adam Trachtenberg replied 14 years, 1 month ago 3 Members · 6 Replies -
Adam Trachtenberg
July 28, 2012 at 6:57 pmI think the problem is that you simply don’t have enough grass to hide the ground underneath when it rises up, reducing overlap. What you might try is increasing the hair count considerably, but then use a density map to place more of the grass where you need it (without making render times even crazier).
Jason Stirret
July 28, 2012 at 7:28 pmHi Adam, thanks for your help. After some testing I don’t think that this is the problem. If I disable the plane which the grass sits on the hair renders fine (though the sky can be seen through it), i.e. the actual grass strands do not change color or hue midstream. I suppose I could just composite two images in Photoshop but then I would not know where the original problem was.
I have tried setting the plane to black with no specular to see what happens. And as I suspected it is not a dark line in the horizon but that same light line which discolors the grass. I have GI turned off on both sides, the plane as well as grass and that didn’t work either; so I don’t think GI is at the root of my problem. I will beef up the hair count density map it and try your suggestion.
Darby Edelen
July 29, 2012 at 11:17 pmCan you upload an image of what you’re expecting to see (with the plane disabled)? I’m not seeing a problem with the grass colors, so it’d be easier to identify the problem you’re seeing with a second sample image that doesn’t show the problem.
Darby Edelen
Jason Stirret
July 30, 2012 at 7:28 pm -
Darby Edelen
July 30, 2012 at 10:29 pmWhat we’re seeing there are shadows cast from the ground geometry onto the grass.
The Shadow properties under the Illumination tab of the hair material can be adjusted to reduce this.
Shadow Density will affect all shadows, including self shadows, so that likely won’t be the best option.
Reducing the Received Shadow will make the shadow the ground casts less intense, but it will also affect the shadows cast by any other objects so that might also not work.
Lowering the Back Shadow is probably your best option.
Darby Edelen
Adam Trachtenberg
July 31, 2012 at 5:28 amI think you’re on the right track. I’d focus on the back specular and back shadow options as it does seem like the problem is coming from the rim light.
