Activity › Forums › Adobe After Effects › Same footage 2x, one w/alpha, one without?
Posted by Eric Chard on April 29, 2012 at 2:57 pmSame footage 2x, one w/alpha, one without?
I’d like to layer the same footage on top of itself, but have the top layer use the footage’s alpha channel, while the bottom layer ignores the alpha channel.
How would one do that?
Setting Interpretation globally affects BOTH Layers, I want to have one WITH, one WITHOUT.
THANKS!
“Putting the HARM in ‘harmonica’ since 2005.”
++++++++++++++++Darby Edelen replied 14 years ago 3 Members · 7 Replies -
John Cuevas
April 29, 2012 at 3:11 pmAre you looking to have a Background color on the bottom layer? You could add Channel -> Solid Composite to the bottom layer.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Eric Chard
April 29, 2012 at 8:40 pm2 layers, same footage.
There is color information in the alpha area. I want to use that color informaation as the background. So, the bottom-most layer will not use its alpha, while the layer above, same footage, will use its alpha.
John Cuevas
April 29, 2012 at 9:10 pmOkay I just tried this, I imported a graphic with an alpha channel and left it alone. Then I imported the graphic again, so I have two copies of it and set the interpretation to ignore. Same video with and without alpha channel. Is that what you are trying to accomplish?
Eric Chard
April 30, 2012 at 3:35 pmSo simple? Dang! So, just import it twice, with different interpretations.
–I’m banging my head on my desk here.
Darby Edelen
April 30, 2012 at 3:35 pm[John Cuevas] “Okay I just tried this, I imported a graphic with an alpha channel and left it alone. Then I imported the graphic again, so I have two copies of it and set the interpretation to ignore. Same video with and without alpha channel. Is that what you are trying to accomplish?”
You can also duplicate (cmd-d/ctrl-d) your footage item directly in the Project Panel and change its interpretation. You can even rename the individual instances of the footage item in the project panel to keep things clear.
Or you can duplicate the layer in the timeline and apply a Channel > Shift Channels effect with Alpha set to Full On.
Darby Edelen
John Cuevas
April 30, 2012 at 4:21 pmGeez Darby, now I feel dumb for only coming up with one solution.
Darby Edelen
May 1, 2012 at 6:01 pmHaha! It’s an Adobe application, there are always 10,000 ways to do it. Even keeping track of a fraction of them takes up a good bit of brain space.
I’m seriously afraid that when I get into my rocking chair years I’ll be mumbling about blending modes and matte layers to my grandchildren.
Darby Edelen
