Activity Forums Square Box CatDV Same field name (but duplicated) = same query results?
  • Same field name (but duplicated) = same query results?
    Posted by Carla Vidal on April 1, 2015 at 12:26 pm
    Hi there,
    It might be a stupid question but I would like to make sure of this issue.
    I have a NOTES (red) user defined field which we have been using so far.
    I realised that there is a built in field also named NOTES (green). I have been changing things in both detailed panel and search panel and now I am worried if I changed from one NOTES green to the other NOTES red -or viceversa- and that implies not getting all the results because the program understands it as two different fields…
    Thank you in advance for helping
    Cheers
    Carla
    Carla Vidal replied 11 years, 3 months ago 2 Members · 2 Replies
  • Dougal Matthews
    April 15, 2015 at 10:31 am
    hi Carla
    you can use the Bult edit tool to append the contents of one field to another i suggest in your case you move the contents of your user created ( red ) notes field to the built in ( green) notes field
    if you use the append option you will add the red notes to any existing green notes
    Use Bulk Edit as a flexible tool to copy one field to another or automatically renumber clips. Select the destination field whose value you want to set, then either type in a fixed value to use or select another property to copy or move to the destination. To use automatic numbering type in a value like “Scene 009″ and the next line will automatically be incremented to “Scene 010″ etc.
    thank you dougal
    Improvise Adapt and Overcome
  • Carla Vidal
    April 15, 2015 at 3:20 pm
    Yes I know the bulk edit tool, thank you for the detailed explanation. It’s been very useful since I didn’t think about it to solve the problem. Thanks!
