Activity Forums Avid Media Composer “Same as Source” not working anymore
  • “Same as Source” not working anymore
    Posted by Jonathon Corbiere on August 20, 2008 at 10:42 pm
    Has anyone else encountered issues exporting HD “Same as source” quicktimes from their Avid Media Composer. (v.275 and fully updated quicktime)
    Our sequences and footage is transcoded to DNxHD 36 so that our edit stations can stream over our network and have never ran into this problem until recently.
    Every time we export a “same as source” the final file is the right file size, opens in quicktime, but plays in the most odd ways, dropping frames here and there, jumping ahead to other scenes and flashing frames from later on in a show, etc.
    Exporting quicktime “reference” files or any other type of output works fine so it’s quite strange that SAS is doing this.
    We are running Windows XP professional, updated with fully updated AVID MC before 3.0. I would appreciate any help we could get on this.
    Thanks for any insight you may have.
    Jonathon Corbiere replied 18 years, 1 month ago 2 Members · 6 Replies
  • Job Ter burg
    August 21, 2008 at 6:26 am
    Are you using the correct version of QT?
  • Jonathon Corbiere
    August 21, 2008 at 4:41 pm
    We are using Quicktime 7.5 and AVID Media Composer 2.85 as well as a few machines with 2.72, the same as source problem is occurring on both versions.
    Thanks for your help.
  • Job Ter burg
    August 21, 2008 at 5:45 pm
    You should not use QT 7.5 with those versions of MC.
    You should be on QT 7.2 for MC 2.7.x and on QT 7.3 for MC 2.8.x
    Pay close attention to the Avid system specs, and follow them religiously.
    [url]https://avidtechnology.custhelp.com/cgi-bin/avidtechnology.cfg/php/enduser/std_adp.php?p_faqid=75147&p_created=1202760115&p_sid=HwhT_v_i&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NDYsNDYmcF9wcm9kcz0yNzYmcF9jYXRzPTAmcF9wdj0xLjI3NiZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bWF0cml4&p_li=&p_topview=1[/url]
  • Job Ter burg
    August 21, 2008 at 5:47 pm
    Link got screwed up:
    https://tinyurl.com/2o6jn5
  • Job Ter burg
    August 21, 2008 at 5:50 pm
    My bad, 2.7.2 needs QT 7.1.6
  • Jonathon Corbiere
    August 21, 2008 at 11:18 pm
    Thanks a lot for your help and the Avid link.
    This did indeed fix the problem! We uninstalled our quicktime and reinstalled the older/compatible version and now “Same as Source” works again. I work at a school and it turns out the students were running iTunes and updating our quicktime versions automatically somehow, anyways IT is figuring it out and now that we know the issue it’ll be easier to be proactive about in the future.
    We will be consulting this version matrix from now on while troubleshooting.
    Regards,
    Jon Corbiere
