Activity › Forums › Avid Media Composer › Same as source export gone wrong!
  • Same as source export gone wrong!
    Posted by Juan Juig on July 15, 2016 at 12:27 pm
    I have tried exporting my project as Same as source as I would like to keep as much information as possible. The video export is excellent, I see no difference from the source. However the audio is different than the source. It has lower bitrate and the sound depth is 16bit instead of 24bit.
    I have also tried exporting as DNxHD 185x (the same as source), however if I compare the export to the source, the colours in the export are not exactly the same as in the source. Every frame is a bit brighter and I do not want that.
    So is there any way to change the audio when exporting with the Same as source option?
    Pat Horridge replied 10 years, 2 months ago 4 Members · 3 Replies
  • Shane Ross
    July 15, 2016 at 6:45 pm
    Are you comparing what you see in the Avid interface with what Quicktime is showing you? because the Avid interface…Source and Record monitors…is not color accurate.
    Shane
    Little Frog Post
  • Michael Phillips
    July 15, 2016 at 9:57 pm
    Nor would I really trust a .mov file playing in MoviePlayer either. This is a case of two wrongs not making it right. 🙂
    Michael
  • Pat Horridge
    July 16, 2016 at 8:15 am
    Do an audio mixdown to a new track at 24bit 48khz
    Then replace the seq audio with that.
    To be safe I’d also replace the video with a dnx185x mixdown. Then do a SAS of that.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
