Salvaging an AVID project that needs to move to Premiere, replace .mxf
I am working on a web series, and I cut one episode in AVID because I wanted to re-learn the program. I didn’t really understand the workflow, so I ended up with .mxf files.
When I exported from .mxf, there was significant quality loss from the original footage.
I’ve moved away from the producers, so I need to move the project to premiere so that I can email the project file. I don’t have the original tapes, but I do have the footage in a mix of .avi and .mov files. The .avi and .mov are from a different capture and not the same length as the .mxf files, but the same footage is in there.
I tried saving the AVID project as a .aaf and opening in Premiere, but it can’t read .mxf so it says everything is offline.
I’m wondering the best way to rescue my project. It seems like if I could import the .avi and .mov files into AVID and then make subclips the same length as the .mxf files and replace the .mxf with those subclips, I could then import the project into Premiere.
I’m not sure how to do this. Suggestions would be appreciated.
