Activity Forums Apple Final Cut Pro Legacy Safe to use ProRes Proxy for the Web?
  • Safe to use ProRes Proxy for the Web?
    Posted by Josh Williams on September 6, 2011 at 11:47 pm
    I have about 88 hours of footage (4 cameras @ 22 hours each) that I am doing a large multi cam edit on. Not all 88 hours into one piece but many small pieces. So far I have converted it all into ProRes Proxy for editing and I intended to reconnect it to ProRes LT when I was ready for export.
    However since the end products are going to be on a website would it be ok to use ProRes proxy and just export from that? When I look at it after exporting to h.264 720p and uploading to youtube it is really not bad.
    Or am I just going to be shooting myself in the foot by not reconnecting to the higher ProRes LT.
    Am I just being lazy and cutting corners?
    Ron Pestes replied 15 years ago 3 Members · 4 Replies
  • Josh Williams
    September 7, 2011 at 12:00 am
    Or I guess I don’t even need the proxy files right? I can just have everything as ProRes 422 LT and just edit those files.
  • Shane Ross
    September 7, 2011 at 1:03 am
    ProRes Proxy has plenty of quality for web output. Do tests and see for yourself. That’s the best way to judge…YOU look and see what you think.
    Shane
  • Josh Williams
    September 7, 2011 at 1:15 am
    Yeah. I just tested a proxy vs an LT and I really could not see a difference in most cases. And I think if we are finishing out to 720p for the web we should be good
  • Ron Pestes
    September 7, 2011 at 3:48 pm
    You should be fine with Proxy. Go for it.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    New convert to Adobe CS5.5 Production Premium
