Activity Forums Broadcasting Safe Title/Action in 16:9
  • Safe Title/Action in 16:9
    Posted by Mike Sussman on November 7, 2008 at 8:23 pm
    So as I’ve always understood it in 4:3 world safe action is 90% full screen and safe title is 80% full screen. Since the screen is wider than it is tall, the left and right “margins” are slightly wider than the top and bottom, but not too noticable. That’s all fine, but in the wider 16:9 aspect ratio, the difference between these 90%/80% margins become even more drastic and noticeable. The margins on the left and right are now much wider than the margins on the top and bottom.
    My question is whether safe title and safe action are still 90% and 80% in the wider 16:9 aspect ratio? For one, the difference between the top and bottom margins seems overly obvious. But also, I would think that modern non-tube monitors have much less “at-risk” area around the edges, so you should be able to fill the screen a little more with confidence. No?
    Del Holford replied 17 years, 10 months ago 2 Members · 1 Reply
  • Del Holford
    November 7, 2008 at 9:27 pm
    Our studio has Sony PFM-510 plasma monitors. Since they have a bit of overscan in them we build our graphics inside the monitor scan we see. We have a crt HD monitor for fine tuning but what I see at home is about the same. We letterbox downconvert for our current analog channel and 10% on the sides is safe. We may use only 5% on the top & bottom because in the letterbox it looks dorky to have it higher.
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
