Activity › Forums › VEGAS Pro › Safe shows well DVD Architect except for when I burn it
  • Safe shows well DVD Architect except for when I burn it
    Posted by Ed Jones on July 10, 2010 at 11:18 pm
    Hello,
    I rendered a video as mpeg, VCD NTSC,624 X 480. When I burned the file to DVD all of the crossfades and transitions were choppy. I then rendered it as a mpeg 2,DVD NTSC, 624 X 480 and everthing was fine except for now all off the video is chopped off the TV screen when I put it in a DVD player. Even in DVD Architect it is inside the safe area but when I put it on DVD it is chopped off. How can I fix this.
    Ed Jones replied 16 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    July 11, 2010 at 12:36 am
    NTSC is 720×480 PAR 0.9091 so that is what you should be rendering to. That is also what your project properties should be set to. There are Safe Area markers that show you the Action Safe and Title Safe areas. The Action Safe area is what is guaranteed to be shown on TV. All of your titles should be within the title safe area.
    TV sets DO NOT show all the video. They never have. There is an area that is different for every TV that is never seen. There is nothing you can do about this since you can’t predict how much will be lost with each TV set.
    Set you project to: NTSC DV (720×480, 29.970 fps)
    Render to: MainConcept MPEG2 Template: DVD NTSC
    See if that helps.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ed Jones
    July 11, 2010 at 2:20 am
    I set it to those settings you recommended:
    (720×480,29.970 fps mpeg2, template DVD NTSC) and rendered it. I then transferred it to DVD Architect. Everything is inside the safe area inner dotted line box but when I burn it to DVD and put it in 3 DVD players on 3 different TV the video is chopped off around the edges and I lose valuable text.
  • Stephen Mann
    July 11, 2010 at 4:42 am
    Are you looking at title-safe or action-safe? Typically 15% and 10% respectively.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Ed Jones
    July 11, 2010 at 1:45 pm
    Ok I’m slightly confused on which is title safe area and action safe area but my video is right inside the 2nd outer dashed line. When I burn it to DVD it chops off valuable text. The size works out fine when I render as mpeg1 and burn it to DVD but I need mpeg 2 for the transitions/effects to show properly.
    Not sure what to do.
  • John Rofrano
    July 11, 2010 at 2:44 pm
    Yea, as Steve said, the text needs to be witin the Title Safe area which is the inner dotted line when you turn on safe areas in Vegas. Like this:
    ~jr
  • Ed Jones
    July 11, 2010 at 2:53 pm
    Ok mine is right inside the Action safe area. On track 1, I have like 150 powerpoint jpeg slides that are 960 X 720. I guess when I saved the slides from microsoft powerpoint to a jpeg that was the default dimensions. Would i have to resize the source files from microsoft powerpoint or is there a way to squeeze it inside the title safe area in vegas.
    Thanks for you guys help
  • Stephen Mann
    July 11, 2010 at 3:49 pm
    You could use ‘track motion’ to resize every event on the track to fit in the title-safe area.
    Steve Mann
    http://www.mmdv.com
  • Ed Jones
    July 11, 2010 at 5:29 pm
    Thank you, thank you Steve. Track Motion worked. Thank you to John for the explanations and rendering specs. Great forum.
