Activity › Forums › DVD Authoring › safe settings
  • safe settings
    Posted by Sven Jenson on March 8, 2007 at 10:28 am
    dear pro,
    recently i created a dvd project using avid xpress pro hd for editing sorenson compression suite for encoding and adobe encore 2.0 for authoring and philips dvd+R lightscribe blank discs for the fancy finish.
    i exported a quicktime reference from avid (HDV-material) and encoded it as follows:
    Mpeg2, 2-pass VBR, data rate 3000, format PAL, 720×576, frame rate 25, 4:3, upper field first, I-frame rate 15fr.
    i finally put it in encore, encoded it and the finished dvd+r works just fine (on my dvd floppy).
    when i put it into the dvd player it starts choking every now and then, which is not that satisfying.
    i tried several encoding bit rates, but the problem stays the same.
    i think it is probably because of the dvd+r (i didn´t use dvd-r so far), because as i know dvd+r sometimes causes problems on older players.
    any suggestions how to solve this prob?
    Vincent Rosati replied 19 years, 5 months ago 2 Members · 1 Reply
  • Vincent Rosati
    April 12, 2007 at 5:12 pm
    DVD+R does not hold the DVD logo because it does not meet the industry spec’s for DVD-Video. While DVD+R may play in many players, it’s not ideal.
    I’ve never had any issues burning data discs on +R, but for video it’s not reliable.
    Note: DVD+R holds slightly more data than a -R. Hopefully your DVD project will fit on a standard DVD-R.
    If you need to use DVD+R, you could try Bitsetting the disc as a DVD-ROM (instead of DVD+R). It might be an option in your burning software or your burner manufacturer might offer a utility.
    Burn at your drives slowest speed and always verify the burn with your burning software.
    Another requirement for some older players is to include the AUDIO_TS directory, it’s a legacy standard.
    Just some thoughts.. : )
