Activity Forums Adobe After Effects Safe colours for HDTV broadcast
  • Safe colours for HDTV broadcast
    Posted by Jan Vork on March 21, 2013 at 9:26 am
    For 8bit PAL, RGB values from 16-235 are safe for broadcast.
    Does anyone know these values for 16bit HD?
    There are some standards:
    ITU-R Recommendation BT.709-5
    R103-2000
    but both seem to live in the analog domain, talking about microvolts and ranges from -1% to 105%.
    What I would like to have and spread is the digital safe values for 16bit (full range = 0 – 32768).
    Thanks a lot!
    Jan Vork
    (Jaydude)
    http://www.jaydude.nl
    Jan Vork replied 13 years, 6 months ago 46,370 Members · 1 Reply
  • Jan Vork
    March 21, 2013 at 4:01 pm
    Thanks for your solution, Dave!
    I was wondering if there are other values around. I can imagine that digital HD is somewhat more tolerant than analog PAL…
    Found this clipping indicator solution:
    https://joshuamosley.com/tutorials/AfterEffectsColorSafeHD/
    It’s for SD, but seems to work for HD as well.
    Still not very satisfying. I want values to put in an Adjustmentlayer, or an AE-plug that works for HD.
    What about AE’s color settings? When I set my profile to 709, the output is visually less extreme, but the ‘clipping indicator’ still tells that the whites are illigal…
    Why is this such a mystery?
