Activity Forums Adobe Premiere Pro Safe area/margin
  • Safe area/margin
    Posted by Prochris on November 28, 2006 at 6:14 am
    I’m creating a video that is only going to am played in DVD format, and only on a TV. Should I then change all of my edited video to dit inside the safe margin? There’s nothing particularly important outside the margin, but rather that the whole frame is seen that having bits but off…
    Chris
    Mike Velte replied 19 years, 9 months ago 2 Members · 3 Replies
  • Mike Velte
    November 28, 2006 at 12:27 pm
    Most folks do not resize video clips to fit inside the safe margin. If the video was framed properly during shooting, it is not necessary.
  • Prochris
    November 29, 2006 at 5:44 am
    OK, Thanks
    I’ll keep that in mind. Now, while we’re on the subject of DVD anthoring, I’m wondering about bitrates etc. I’m trying to fit either 2 hours each onto 2 DVD’s, or 4 hours on one DVD-9. There’s lots of motion, so what settings should I use, eg: M frames, VBR etc.
    Thanks again
  • Mike Velte
    November 29, 2006 at 12:13 pm
    For a limited distribution (one or two), dual layer discs might be fine, but they have more compatibility issues than D5s.
    For two hours on a single disc, your average bitrate should be 4400 kbps for video + Dolby audio. Choose 2 pass vbr; 2000 kbps minimu, 4400 kbps target and 7000 kbps maximum. Dont mess with the GOP configuration or you might create non conforming video.
    I have a bitrate chart on my web;
    http://www.video2stream.com
