Activity Forums Apple OS X Safari Beta 3
  • Safari Beta 3
    Posted by Steve Denn on July 6, 2007 at 11:55 pm
    By installing Safari Beta 3 does that overwrite the Safari 2.0.4 that comes with Tiger?
    or can you have two seperate versions of Safari?
    Mitch Ives replied 19 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • 13 Create COW Profile Image
    13
    July 7, 2007 at 3:44 am
    Yes it douse over right the previous version of safari.
    If you really must keep it then move the old file out of the application folder and then install the beta. Just make sure that you rename the old version before moving it back to the apps folder.
    However I see no reason that you need the old one the Safari 3 Beta ROCKS.
  • Steve Denn
    July 7, 2007 at 12:00 pm
    Please explain why you think it ROCKS. What does it do better or different than the older version.
    Thanks for the info.
    13
    July 7, 2007 at 3:39 pm
    Most people wont be able to tell a difference, but it is a bit quicker, Also the way the search feature works in the new version is GREAT.
  • Greg Serafin
    July 11, 2007 at 2:07 am
    There are some issues with the MAIL APP after installing SAFARI 3,
    Have a look at the apple discussions.
    For now, uless you “have to” IMHO – don’t install 3.
    13
    July 11, 2007 at 4:47 am
    I have had absolutely no problems with mail or any other app since installing safari 3
  • Greg Serafin
    July 11, 2007 at 5:31 am
    Lucky you then,
    I am one of many for whom the mail plays up while Forwarding a message with an attachment. The attachment appears in the FWD, but not the message text itself.
    I am not dissing the Beta, but thinking back I wouldn’t have installed it.
    Better wait for the next update.
    https://discussions.apple.com/forum.jspa?forumID=1187&start=15
    iq
  • Alan Okey
    July 11, 2007 at 2:53 pm
    By using the uninstall utility that is in the Safari 3 Beta .dmg folder, you can roll back to the previous version.
  • Mitch Ives
    July 25, 2007 at 3:55 pm
    [Alan Okey] “By using the uninstall utility that is in the Safari 3 Beta .dmg folder, you can roll back to the previous version”
    Hasn’t helped. We tried Safari 3, it kept crashing on a new Intel MBP. The machine also opens the applications window every time we power up the machine, which it never did before. Nothing can get rid of that. Of course, all the other issues with other programs reported in 3 still remain…
    Removing 3 and going back to 2 does not eliminate that window opening. The autofill option also no longer works, so we have to type everything in manually in web forms now. Nice.
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    Apple Certified Trainer: Final Cut Pro 5
