Activity › Forums › AJA Video Systems › S-Video Capture Problem
  • S-Video Capture Problem
    Posted by John Fishback
    on February 12, 2006 at 9:09 pm
    All of a sudden I can’t capture s-video with the IO. It worked fine last time I needed to do this about a month ago. Nothing has changed since then. I checked all the cables and tried two different machines. No go. The AJA is not showing s-video on its front panel indicator. Component and composite capture work fine. Anyone have any ideas?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
    John Fishback
    replied 20 years, 7 months ago
    2 Members · 4 Replies
  • Jeremy Garchow
    February 12, 2006 at 9:44 pm
    Are you using an SVideo easy setup?
  • John Fishback
    February 12, 2006 at 10:13 pm
    I was trying to capture s-video to 8-bit uncompressed. My normal capture is component NTSC 8-bit uncompressed. In the past I just changed the capture mode to s-video 8-bit uncompressed in the capture dialog.
    John
  • Jeremy Garchow
    February 12, 2006 at 10:14 pm
    Okay, try using the s_video to 8bit uncompressed easy setup and see what happens.
  • John Fishback
    February 12, 2006 at 10:24 pm
    I’ll give that a try. Thanks.
    John
