Activity › Forums › Apple Final Cut Pro Legacy › Rwndering text
Rwndering text
Posted by Claudio Papapietro on September 24, 2010 at 4:06 amFCP wont render text if I have added a motion effect such as changing the opacity. If I remove the motion effect it will render fine. There is no error message, it just wont do it. Any ideas? Thanks!
Claudio Papapietro replied 16 years ago 2 Members · 4 Replies -
Jerry Hofmann
September 24, 2010 at 3:46 pmWhat are your sequence settings, and what is the format of your source material?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Claudio Papapietro
September 24, 2010 at 4:54 pmThanks for responding, Jerry. The source material is still photos. Sequence settings are: pixel aspect ratio: square; field dominance: none; QuickTime: h.264. Thanks again!
Jerry Hofmann
September 24, 2010 at 7:32 pmYour problem is H.264. FCP doesn’t support it. Put the original stills (JPEG, Whatever) in a ProRes sequence.
Jerry
