Activity › Forums › Avid Media Composer › runtime error
  • runtime error
    Posted by Michael Volkening on January 5, 2008 at 1:15 am
    I, like may, have developed a runtime error problem. Mine may be a little different- I have not installed or changed anything- and the error only occurs in one project. Here’s my story:\
    I have been working on this program for 3 days. All went well until recently when I received this error. It occurred when I was dropping a transition effect on to an edit point. (A saved one I have been using successfully for 2 days):
    Runtime Error!
    Program: C\Program Files\Avid\AvidXpressPro\AvidXpressPro.exe
    The application has requested the Runtime to terminate it in an unusual way. Please contact the application’s support team for more information.
    When I click okay, the error message disappears for a moment, the re-appears. Clicking okay the second time closes the application. Here is what I have done trouble-shooting wise so far: If I open a different project, all is well. Everything works. I have opened several other current projects and they all function properly. I have closed and re-opened the Avid software several times. I have restarted the computer. I have completely shut down the computer. I have turned off the power to everything, waited a while, and started over. I get the same error message every time I open this one project only. I tried duplicating the sequence (which is in its own bin) but it crashes before I can do so.
    I am going to pretend for the moment that It knows that it is Friday afternoon, and if I shut down for the weekend all will be well when I return Tuesday. However, if that turns out to be not the case, I present this dilemma for your always valuable opinions/suggestions.
    Avid Xpress Pro Mojo, Windows XP 2002.
    Mikey
    Michael Volkening replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
