Activity Forums Adobe After Effects running footage backwards
  • John Dickinson
    May 25, 2005 at 9:48 pm
    Select the footage and press Command Option R (mac) or Control Alt R (PC). Be careful though as this will also reverse any keyframes applied to the layer. You can also use Time Remapping (LAYER > ENABLE TIME REMAPPING). Select the keyframes that are applied by default and time reverse them (ANIMATION > KEYFRAME ASSISTANT > TIME REVERSE KEYFRAMES). With this method any keyframes already applied to the layer will not be reversed.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
