Activity Forums Adobe Premiere Pro Running CS6 on a PC?
  • Running CS6 on a PC?
    Posted by Mark Welch on June 19, 2012 at 11:40 pm
    I switched to Premier a few months ago, now upgrading to CS6. Thinking of leaving the mac since my iMac just isn’t quite up to the demands of video editing.
    A Mac Pro for about $3K+ would do the trick but my son in law (an IT guy)has built up several PC’s and wants me to migrate to Windows. My question is, having a good geek build a computer for an editing system a good idea? He can save me hundreds, maybe a thousand dollars or more, but what pitfalls lie ahead for the do-it-yourselfer?
    Mark Welch replied 14 years, 3 months ago 2 Members · 2 Replies
  • Alex Gerulaitis
    June 20, 2012 at 12:43 am
    As long as he can follow some basic guidelines in terms of system configuration for video editing, no pitfalls that I can think of.
    Will your son-in-law be available in case something goes wrong (hard drive dies)?
    Might be a good idea to post the proposed configuration (a list of components) here for some crowd-vetting.
    Finally, if you do need to call someone for application-specific support (e.g. why does Premiere Pro drop frames on this timeline and not the other; how do I fix it?) that your son-in-law may not be able to answer, then consider getting a complete system from a video integrator (ADK, Puget).
    (Not suggesting Boxx, HP, etc. – those will cost on a par with a Mac Pro.)
    Alex (DV411)
  • Mark Welch
    June 20, 2012 at 12:49 pm
    Good point Alex.
    I run into enough issues on a system designed to edit video as it is. Going homemade may not be worth the savings.
