Activity Forums Boris FX Running clock
  • Running clock
    Posted by Michael Allen on April 1, 2005 at 3:44 pm
    I need a digital clock running in the bottom right hand corner of the screen for a trauma video that I am producing for a local hospital (I need hours, min., and seconds.) I would like to superimpose it over the video (like the series
    Michael Allen replied 21 years, 5 months ago 2 Members · 2 Replies
  • Steve Pankow
    April 1, 2005 at 4:03 pm
    If your NLE supports Red as a plugin, you can simply put it over the portions of your timeline where the clock is needed and adjust accordingly. I assume you know that Red can generate timecode and clock time internally? It almost sounds as if you want to videotape a clock and then use Red as a compositing tool to place it over your video.
    Another way would be to set up whatever clock “times” you need in Red running on its own and render them out as Quicktime movies that would be imported into your NLE later. HTH.
  • Michael Allen
    April 1, 2005 at 4:39 pm
    I have red. Where can I find the clock feature?
