Activity Forums Apple Final Cut Pro Legacy Running a monitor for FCP 4.5
  • Running a monitor for FCP 4.5
    Posted by Frosch on February 28, 2006 at 2:49 am
    Hello,
    I’m just wondering if it is possible and what I would need to run a monitor or small television out of a G4 (733mhz) with FCP 4.5. (Also, viewing After Effects projects wouldn’t hurt either!)
    Right now I’m using a single 20″ monitor for my workspace, but it would be nice to see what I’m working on on a small monitor. I’d probably need specific video card/cables etc, but which ones?
    I’m obviously no engineer, so I apologize for my lack of knowledge on the subject. I’m just used to working in edit suites where everything is already “set up”, now I want to acheive the same thing at home.
    If my setup discription is too vague, I could post more info.
    Scott
    David Battistella replied 20 years, 6 months ago 3 Members · 3 Replies
  • Enzo Tedeschi
    February 28, 2006 at 2:55 am
    The easiest option if you are cutting DV is to run your firewire cable to your DV deck, and from there to your TV/monitor. The deck will do the D/A conversion, as long as you have External Video set to All Frames within FCP.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Frosch
    February 28, 2006 at 2:03 pm
    That’s a great suggestion, but what if I’m only using a mini DV cam, and don’t have a DV deck?
  • David Battistella
    February 28, 2006 at 2:10 pm
    Take the video outputs from the camera. Either S-Video or composite to the TV.
    Make sue the firewire is going to the computer.
    David
    Peace and Love 🙂
