Activity Forums Adobe After Effects Expressions Runing a function in nested comps in AE
  • Runing a function in nested comps in AE
    Posted by Mateo Mazzini on April 23, 2018 at 4:09 am
    Hi! I am trying to create a function which extends the outpoint of every layer in a comp.
    I need the function to detect when the layer is a precomp, enter it, and run again inside of it.
    so far, if I call the function within itself I create a loop which hangs AE.
    Any ideas on how to approach this?
    (Check line 23 ==> extendOut(activeSubC.layer(u).source) <== this is where I am crashing AE. this is not working… if you delete this line, the script works just fine for the first selected layers and it’s firsts precomps. but not for precomps inside those.
    thanks!
    app.beginUndoGroup(“extendOut”);
    //DEFINING GENERAL VARIABLES
    var activeC = app.project.activeItem;
    var activeSel = activeC.selectedLayers;
    //THE FUNCTION THAT RUNS INSIDE EVERY PRECOMP SELECTED.
    function extendOut(compToExtend){
    var activeCItems=compToExtend.numLayers;
    var activeSubC=compToExtend;
    for(u=1;u<=activeCItems;u++){
    //DEFINE THE VARIABLES FOR THE SCRIPT
    var currentSubLayer=activeSubC.layer(u);
    var inSubLay=currentSubLayer.inPoint;
    var activeSubCDuration=activeSubC.duration;
    // EXTENDING A PRECOMP
    if(activeSubC.layer(u).source instanceof CompItem){
    currentSubLayer.source.duration=activeSubCDuration-inSubLay;
    currentSubLayer.outPoint=activeSubCDuration;
    // EXTENDING A VIDEO LAYER
    if(currentSubLayer.canSetTimeRemapEnabled==true && currentSubLayer.source.hasVideo==true){
    currentSubLayer.timeRemapEnabled=true;
    //EXTENDING EVERYTHING ELSE
    else{
    currentSubLayer.outPoint=activeCDuration;
    //RUN THE SCRIPT FOR THE FIRST TIME ONLY FOR SELECTED LAYERS
    for(i=0;i
    Mateo Mazzini replied 8 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
