Activity Forums Adobe After Effects Run script only if comp exists in project
  • Run script only if comp exists in project
    Posted by Danyl Bernard on October 19, 2020 at 4:40 pm
    Hi all,
    I’m trying to create loop that keeps checking if a comp exists. I want the loop to keep running until the comp exists, and once the comp is found run the rest of the script.
    So far I have a basic for loop, but it doesn’t seem to be doing anything
    for (var i=0 ; i<app.project.numItems.length; i ++)
    if (app.project.item(i). name != “FINAL 2”)
    break;
    Thank you
    Danyl Bernard replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
