Activity › Forums › Adobe After Effects › Run headless After Effects on a server
  • Run headless After Effects on a server
    Posted by Dan Thomas on April 30, 2013 at 11:22 pm
    On my local machine, I can execute a command line that invokes my local copy of After Effects, which will of course run any scripts in the scripts/startup directory.
    How do I do this same thing on a server? Can I install a copy of After Effects on the server? How would I even do that, I’ve never installed any apps on a server before. thanks
    Dan Thomas replied 13 years, 5 months ago 2 Members · 2 Replies
  • Alex Gerulaitis
    May 1, 2013 at 1:07 am
    Two questions in one:
    1. Can you install AE on a server?
    2. How do you run a script on a remote system?
    I’ll take a swing:
    1. I haven’t tried it; it’s not formally supported; yet unless Adobe specifically prevents it, it will install. Another option, which I’d personally prefer: install it on a virtual Win7 or Win8 machine instead, under a hyper-visor on that server. Much cleaner, more portable, easier to manage. Bottom line, it’s possible to install AE on a server.
    2. Yes you can.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Dan Thomas
    May 1, 2013 at 4:11 pm
    Ok, cool, I will look into the virtual machine solution. Thanks!
