Activity Forums Adobe After Effects Run external script from within After Effects
  • Run external script from within After Effects
    Posted by Ole Sturm on May 5, 2014 at 9:37 pm
    Hi everyone,
    I’m currently working out of a studio where all the computers are in lock-down which makes it impossible for me to install my scripts that I have come to rely on. I’m wondering whether it’s possible to launch a script from within After Effects when that script is not installed within the scripts folder?
    Many thanks
    Walter Soyka replied 12 years, 4 months ago 3 Members · 3 Replies
  • Ole Sturm
    May 5, 2014 at 9:40 pm
    Rephrased my question on Google and found this over on aescripts:
    If you are a freelancer sometimes you don’t have access to the ScriptUI Panels folder. Here is a tip on how to run scripts outside of that folder.
    Save the script anywhere you have access like the Desktop or Documents folder
    If the script extention is .jsxbin, then rename it to be .jsx
    In After Effects choose File -> Scripts -> Run Script File
    And choose the script file from the Desktop of where ever you saved it
    You won’t be able to dock the script but it should be able to run normally otherwise
  • John Cuevas
    May 6, 2014 at 12:02 am
    Good tip, thanks.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Walter Soyka
    May 6, 2014 at 1:18 pm
    If you are running Ae CC 12.2, you can drag and drop scripts into the project panel, and they will install in a user directory instead of alongside the app.
    You can also manually install scripts into one of these user folders:
    PC:
    \Users\[user_name]\AppData\Roaming\Adobe\After Effects\12.2
    Mac:
    /Users/[user_name]/Library/Preferences/Adobe/After Effects/12.2
    See here for more:
    https://helpx.adobe.com/after-effects/using/whats-new-12-2.html#scripts-ae
    Walter Soyka
