Activity Forums Adobe After Effects Expressions run expression on specific frame
  • run expression on specific frame
    Posted by Jason W. miltt on June 10, 2009 at 10:00 am
    hi:
    i am using a jello style effect on one of my animations. I would like to offset it by 10 frames so i can scale the layer and then at the end the effect appears. i dont know how to change this in the expression.
    Also, is it possible to trigger it at different times? Maybe add a keyframe and the expression kicks in when it reaches it?
    Thanks.
    This is the expression:
    var maxJiggleAmount=effect(“amount”)(“Slider”);
    var jiggleSpeed =effect(“speed”)(“Slider”);
    var decayRate=effect(“decay”)(“Slider”);
    var x=transform.scale[0] + maxJiggleAmount * Math.
    sin(jiggleSpeed * time)/Math.exp(decayRate * time);
    var y=transform.scale[0] * scale[1]/x;
    [x,y]
    Jason W. miltt replied 17 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 10, 2009 at 12:40 pm
    Try it this way:
    var startFrame = 10;
    var t = Math.max(time – framesToTime(startFrame), 0);
    var x=transform.scale[0] + maxJiggleAmount * Math.sin(jiggleSpeed * t)/Math.exp(decayRate * t);
    [x,y]
    Dan
  • Jason W. miltt
    June 10, 2009 at 6:10 pm
    you should charge for this. 🙂
