Activity Forums Adobe After Effects Expressions run expression every 2 frames.. every 3 frames etc?
  • run expression every 2 frames.. every 3 frames etc?
    Posted by Sergio Juyak on October 1, 2008 at 6:14 pm
    I have a very simple expression for the position prop that makes a layer jump around:
    x = random(500, -500);
    y = random(500, -500);
    position + [x,y];
    This makes my layer jump around every frame really fast… i’d like the expression make my layer change positions more slowly, say, every 3 frames or 5 frames… is there a way i can have AE run the expression only once every 3 or 5 frames? If not is there an alternate method? I don’t think wiggle will work because this will “wiggle” the position… and i need “jumpy” or “blinky” movement… thanks
    Dagur Maunason replied 9 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Eric Sanderson
    October 1, 2008 at 6:21 pm
    probability = 3;
    r = (random(-probability+2,1));   //determines how often it wiggles,
    -4,1= 1/6th of the time with a clamp of 0,1
    v = clamp(r,0,1);
    s = wiggle(10, 400*v);
    x = value[0];
    y = s[1];
    [x,y]
    You can define variable probability using random and a clamp, heres an example that i did using text not to long ago…this code only wiggles on the Y.
  • Eric Sanderson
    October 1, 2008 at 6:22 pm
    …sorry, it copied weird…the 2nd and 3rd line shown there is actually all on one line.
  • Eric Sanderson
    October 1, 2008 at 6:27 pm
    probability = 3;
    v = clamp(r,0,1):
    s = random(500,-500;
    x = s[0];
    y = s[1];
    position + [x,y]
    here is the code you would use pertaining to your project…let me know how it works
  • Dan Ebberts
    October 1, 2008 at 7:59 pm
    Something like this should make it change every three frames:
    period = 3; // frames
    posterizeTime(1/(period*thisComp.frameDuration));
    position + [x,y];
    Dan
  • Gianluca Belvisi
    October 23, 2008 at 12:46 pm
    Is there a way to interpolate this “fake” keyframes ?
    Check this out
    https://www.glbproject.it
  • Dan Ebberts
    October 23, 2008 at 3:12 pm
    Like this maybe:
    f = timeToFrames();
    seg = Math.floor(f/period);
    interp = time – framesToTime(seg*period);
    seedRandom(seg-1,true);
    prev = random([-500,-500],[500,500]);
    seedRandom(seg,true);
    next = random([-500,-500],[500,500]);
    value + linear(interp,0,framesToTime(period),prev,next)
    Dan
  • Dagur Maunason
    December 14, 2016 at 12:28 am
    I’ve been tweaking this expression to set opacity to 100 every 20th frame and then fade out again, repetively. It’s all working as I want exept that I can’t for the life of me get it to start the loop at the text layers inPoint. Anyone got an idea of how to achieve that?
    period = 20;
    f = timeToFrames();
    interp = time - framesToTime(seg*period);
    minVal = 0;
    maxVal = 100;
    linear(interp,0,framesToTime(period),maxVal,minVal)
  • Dan Ebberts
    December 14, 2016 at 12:37 am
    One way:
    period = framesToTime(20);
    t = (time-inPoint)%period;
    minVal = 0;
    maxVal = 100;
    linear(t,0,period,maxVal,minVal)
    Dan
  • Dagur Maunason
    December 14, 2016 at 12:46 am
    Flawless! Thank you so much Dan 🙂
