Activity Forums Apple Final Cut Pro Legacy Run AVID and FCP on the same computer
  • Run AVID and FCP on the same computer
    Posted by Sympatric on June 21, 2007 at 6:03 pm
    Hello COW,
    I have an interesting question for you guys. My office is predominantly AVID, I prefer to work on FCP. I would like to setup a “Dual-Room” if you will. On one MAC I would like to run AVID w/ Mojo and FCP with Blackmagic. Has anyone done this before? If so are there any issues that I should be aware of. I would rather not beat my head against a wall if it is never going to work.
    Thanks for any help,
    Patrick
    Debe replied 19 years, 1 month ago 3 Members · 5 Replies
  • Bob Roberts
    June 21, 2007 at 7:05 pm
    It’s physically possible, but the main “gotchas” are which version of the OS and Quicktime each app needs. Right now Avid 2.7 and FCS2 need different versions of each.
  • Sympatric
    June 21, 2007 at 7:46 pm
    Ah…ha! I know there would be something. Thanks for the info. We haven’t upgraded to FCS2 yet and we are still shopping for the new AVID so I am not sure which version of that we will use. I will keep this in mind before I start messing things up 🙂 If anyone can think of anything else I would love to hear it.
    Thanks.
  • Debe
    June 22, 2007 at 3:56 pm
    A dual-boot system would do what you need. Two drives or two partitions (I’d lean towards separate drives myself), each with a full install of the version of the OS most appropriate for each NLE.
    It doubles your system maintenance, but keeps you from having to buy a second computer.
    debe
  • Sympatric
    June 22, 2007 at 8:37 pm
    That is a great idea. I won’t have to worry about any compatibility issues then.
  • Debe
    June 22, 2007 at 10:02 pm
    No problem!
    Have fun!
    debe
