Activity Forums Apple Final Cut Pro Legacy rubber bands are not accurately affecting my volume levels
  • rubber bands are not accurately affecting my volume levels
    Posted by Jason Noto on August 21, 2006 at 10:29 pm
    Hello,
    Does anyone know why my rubberbands might not be working correctly? I have a section in my edit where the music goes from -1dB to -7dB via rubberbanding with the pen tool, but my audio level does not stay put, it quickly jumps back up to -1dB even though the viewer is indicating it should be at -7dB….
    Thanks. I appreciate any insight and info you are able to share
    Jason
    Jason Noto replied 20 years ago 3 Members · 5 Replies
  • Thaxter Clavemarlton
    August 21, 2006 at 11:52 pm
    Try an Audio Mixdown ans see if that helps.
    First, SELECT all of your audio tracks (highlight them) that are involved in that section of the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
  • Chris Poisson
    August 22, 2006 at 12:48 am
    Jason,
    Select your audio tracks and hit option L to make them stereo, that’s where I would start. Also, go to the tools menu and open up the audio mixer, much better control than the rubber bands. Also mix down your audio.
  • Jason Noto
    August 22, 2006 at 10:55 pm
    Jason
  • Jason Noto
    August 22, 2006 at 10:56 pm
    thanks for the help and insight
    Jason
  • Jason Noto
    August 22, 2006 at 10:57 pm
    I was able to fix the problem. Thank you very much!
    Jason
