Activity › Forums › Adobe After Effects › rubber band effect between two objects
Posted by Steven J casey on April 5, 2013 at 3:39 pmCan someone point me in the direction of a tutorial or script to achieve this effect? I have a logo in center and need several other logos to fly out from behind. I’d like them to appear tied to the center logo using 3D stroke (or 2D if that’s what will work) and bouncy as though it’s bungee cords or rubber bands. I haven’t figured out how to link the end points from logo to logo so that the stroke locks in and follows on each end whenever they bounce or move.
StevenDell Precision T7500
Intel Xeon CPU X5650 @ 2.67GHz 2.66 GHz (2 processors)
60GB RAM
Quadro 4000
Windows 7 Ultimate
CS6
M-Audio FW 410
Vegas Pro 12Steven J casey replied 13 years, 5 months ago 4 Members · 7 Replies -
Joseph W. bourke
April 5, 2013 at 3:53 pmHere’s one, easy way to do it with a very inexpensive Script, called Ease and Wizz (you will need to create the connections, maybe using the Pick Whip in an Expression:
https://aescripts.com/ease-and-wizz/
And if you really want to control everything, you’ll need to delve into Expressions:
https://www.motionscript.com/design-guide/elastic.html
Elastic Connection should do the trick…
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Steven J casey
April 5, 2013 at 4:22 pmAny idea how to link the ends of the stroke to each object so that it appears to be the bungee cord? That’s the conundrum I can’t get my head around. I’ve been trying pick whipping things together but haven’t found the combination that works.
Thanks again.
60GB RAM
Quadro 4000
Windows 7 Ultimate
CS6
M-Audio FW 410
Vegas Pro 12 -
Joseph W. bourke
April 5, 2013 at 4:31 pmI’m under the impression that the stroke has no “end” as such, since it’s merely a stroke created by 3D Stroke, and relies on the mask or path for its’ beginning and end. Maybe you need to pick whip the ends of the path to get it to work.
Otherwise, the Beam effect is commonly used for this, since it actually has points at the beginning and end, which can be accessed in Expressions.
There’s another really nice, inexpensive script called LinesCreator:
This will do most of the heavy lifting for you, short of the rubber band effect, which can be done with keyframes, or using the second link I gave you above.
Joe Bourke
Bourke Media
Steven J casey
April 5, 2013 at 5:09 pmLines Creator is looking like exactly what I need, heavy lifting included. Thank you sir!
60GB RAM
Quadro 4000
Windows 7 Ultimate
CS6
M-Audio FW 410
Vegas Pro 12 -
Kevin Camp
April 5, 2013 at 7:09 pmthe beam effect would be another possibility, if the layers are 2d you can use the expression pickwhip to link the ends of the beam to the layers.
if they are 3d layers, then you can use dan ebbert’s 3d-corner-pin expression to handle the layer-space transforms (sounds complicated, but it’s a simple expression):
https://www.motionscript.com/design-guide/threeD-corner-pin.html
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Greg Neumayer
April 5, 2013 at 8:06 pmHere’s a script I did which ties a line between two objects, as well as provides a gap if you prefer not to have the line touch either object:
You can see it here, at :13 sec
https://www.youtube.com/watch?v=b_bVzoERRDMAntifreeze Design
https://www.antifreezedesign.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Steven J casey
April 6, 2013 at 3:39 amWow, thanks for these suggestions as well. Greg, that piece is really cool!
Thanks again
60GB RAM
Quadro 4000
Windows 7 Ultimate
CS6
M-Audio FW 410
Vegas Pro 12
