Activity Forums Adobe After Effects RTL Text Effects
  • RTL Text Effects
    Posted by Amit Zinman on January 17, 2006 at 12:06 pm
    Some of the text effects have a Left-To-Right direction. However, since Hebrew is Right-To-Left, I need it the other way around. Is there a way to change text effects’ direction?
    Amit
    Roland R. kahlenberg replied 20 years, 8 months ago 3 Members · 2 Replies
  • Mylenium
    January 17, 2006 at 12:20 pm
    You should be able to change direction by inverting the start and end values of animators in most cases. For path based text simply reverse the path direction as usual.
    Mylenium
    [Pour Myl
  • Roland R. kahlenberg
    January 17, 2006 at 8:13 pm
    For L-R text effects, say for the word, Hebrew, you’d normally start with the following values:
    Start=0
    End=0
    And you’d probably animate the End parameter until it reaches a value of 6.
    To start from the right, set the Start and End parameters accordingly:
    Start=6
    End=6
    Then you can animated Start so that it reaches a value of 0.
    The logic here is that since Start and End are the same values, the selected range is nil. Then by lowering the value for Start, you will manage to select a range from the right, where the End sort of acts as an anchor and the Start parameter moves the edge of the other end of the range selector.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
