Activity Forums Apple Final Cut Pro Legacy RT popup menu & THANKS!
  • RT popup menu & THANKS!
    Posted by Tom on November 5, 2007 at 6:17 pm
    Hey all:
    First, thanks for all the super-helpful responses to my M100 to FCP switch questions a few days ago…taking all that stuff into account as I decide between Aja and KonaLHe (prob Kona simply for HD downconversion to my SD monitor…)
    ANYWAY – quick question re: the RT popup menu – when I use it during the sequences that came with the tutorial book I’m using – “Final Cut Pro 6 – Professional Editing in Final Cut Studio 2” by Diana Weynand – there are a host of options and little submenus available in the dropdown. BUT – when I create a new sequence (ProRes square pixels 640×480), there are only like 2 options available, and I have to manually go into System Settings > Playback Control to tweak anything else. Cannot find anyhting in the manual, been thru all the menus, etc etc.
    ALSO – still waiting on my RAID (going with G-Speed ES…), so running tutorial files off system drive. Tutorial media is 960×720 ProRe, and dissolves run in real-time from system drive.
    BUT – I rendered out some files in 640×480 ProRes, and no matter what I tweak I cannot get the dissolves to play back w/out render. Ugh!
    If anyone has a second and a (probaly easy) solution would be grateful.
    Tom
    Tom replied 18 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • John Pale
    November 5, 2007 at 6:21 pm
    [tom] “BUT – when I create a new sequence (ProRes square pixels 640×480)”
    Did you just make your own preset for this? this is not a standard frame size. you won’t get any realtime with non-standard frame sizes.
  • Paul Escandon
    November 5, 2007 at 6:32 pm
    Yeah John’s right – unless you’re using a supported Final Cut Pro native preset (there are a ton of them and there’s rarely a reason you’d be working outside on of them) then you’re not going to get the RT options that you’re looking for. ProRes 640×480 is not a default preset so it’s no wonder you’re not seeing the appropriate RT options.
    Try changing your easy set up to a supported FCP preset.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Jeremy Garchow
    November 5, 2007 at 6:35 pm
    First rule when switching from Media100 to Final Cut Pro:
    Throw out 640×480 as a timeline editing frame size. You will either work in 720×480 (for native dv or dv50 stuff) or 720×486 for uncompressed, ProRes or ProResHQ and other codecs.
    Keep 640×480 for square pixel displays (such as making a movie for web delivery/review) but that happens after you export from FCP.
    Jeremy
  • Warren Eig
    November 5, 2007 at 7:47 pm
    Tom,
    Give me a call if you still have questions.
    Warren
    Warren Eig
    O 310-470-0905
    C 310-560-6245
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    https://www.atomfilms.com/af/content/knitwits
    https://www.atomfilms.com/film/family_xmas.jsp
  • Tom
    November 5, 2007 at 8:25 pm
    OK, understand – BUT – files I am starting with were created at 640×480 square pixels – so is workflow now:
    1. Take source files into Compressor first – they come to me at 640×480 square pixels animation codec – and convert to 720×486 ProRes codec, D1 pixels.
    2. Import into FCP.
    2. Edit in FCP in ProRes.
    3. Back to Compressor to convert back to 640×480 square (unbelievable…)
    Is that my workflow?
    Tom
  • Paul Escandon
    November 5, 2007 at 8:57 pm
    Tom,
    That would work. Your biggest issue for being able to edit in real time is that you said you have animation codec files. Final Cut doesn’t work on animation codec files anywhere near real time as you’ve witnessed. Your options are either rendering them whenever you drop them down, or converting them to a codec like ProRes 422 first like you mentioned.
    Paul Escandon
    Oremus Productions
  • Tom
    November 5, 2007 at 9:20 pm
    Going back to web, mainly, with occasional DVD…
    [tom] “1. Take source files into Compressor first – they come to me at 640×480 square pixels animation codec – and convert to 720×486 ProRes codec, D1 pixels.
    2. Import into FCP.
    3. Edit in FCP in ProRes.
    4. Back to Compressor to convert back to 640×480 square (unbelievable…)
    Is that my workflow?”
    Well, what are you doing? Are you trying to go out to videotape, or are you making something for the web? If you’re doing a Print to Tape or an Edit to Tape, can’t you just do it using your ProRes timeline?
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
