Activity Forums Apple Final Cut Pro Legacy RT Playback Issue
  • RT Playback Issue
    Posted by Bill Paris on October 8, 2010 at 7:57 pm
    I have an issue with playback on my system. I’m editing HDCAM 29.97 Footage in Apple Pro Res HQ with a 2X3 GHZ Quad Core Intel Mac with 10 gigs of Ram/Kona 3 Card and ESATA Raid 0 Drives.
    The Problem: The video is choking on playback. I should have enough RAM and the drive speeds should be high enough, but the system keeps choking on playback. It happens just enough that I’m having a hard time outputting our 1 hour show.
    My RT setting are “Safe RT” “Dynamic” Playback and Frame rates.
    Any ideas would be appreciated!
    Bill Paris
    Producer/Director of Photography
    Crew Hawaii Television
    http://www.crewhawaii.com
    Bill Paris replied 15 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Rich Rubasch
    October 8, 2010 at 7:59 pm
    How long is the program and how large is the project? Any large stills in the sequence? Hmmm.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Bill Paris
    October 8, 2010 at 8:29 pm
    Rich,
    The show is one hour …. to help with playback I closed all sequences and created one quicktime file with the hope it would playback without issue. Still not working. The project file is 36mb …. there are a few photos, but it seems to be choking ar random locations. All the media is stored on a freshly cleaned raid.
    Bill Paris
  • Shane Ross
    October 9, 2010 at 12:31 am
    For enough footage for a one hour sequence, that is not a large project file. It is aptly sized.
    What’s the read/write speed on those drives?
    Shane
  • Steve Eisen
    October 9, 2010 at 1:01 am
    And to add to that, how many drives do you have in your raid? Hopefully a minimum of 4.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Bill Paris
    October 9, 2010 at 4:51 pm
    Hi Guys,
    Thanks for your responses,
    I’m away from the office at the moment and will check the drive read write speeds. The raid is a PROMAX esata 8tb raid with 8 drives configured to raid 0, I’m pretty sure they’re 7500 rpm. Before starting this project, I re-formatted the the raid and all the project media including the quicktime clip are stored on this raid.
    One detail that could be important? I have the project file stored on a Drobo raid that is connected to the system via FW800. I’ve never done this before, but wanted to make sure to have the file backed up in case of a drive failure. Could this be causing the playback issue?
    Bill Paris
  • John Pale
    October 9, 2010 at 6:05 pm
    Your drive array sounds like it should be fast enough, however you need to check its actual performance.
    A good way to do that is to download the AJA System Test from https://www.aja.com.
    If your eSATA card is slow, it will vastly underperform. For instance, if you have the $50 2-port Sonnet card you will get MUCH slower perfomance than the more expensive 4 port model.
    [Bill Paris] “One detail that could be important? I have the project file stored on a Drobo raid that is connected to the system via FW800. I’ve never done this before, but wanted to make sure to have the file backed up in case of a drive failure. Could this be causing the playback issue?
    Maybe. Can you try having the project file on your internal drive instead. FW800 is still way slower than your internal SATA connection.
  • Bill Paris
    October 9, 2010 at 6:18 pm
    John,
    Thanks for the info….. I will try the AJA test to see how the well the drives are performing. I do have the 4 port esata card with a second 5TB raid attached. I’ll try moving the project file and seeing what happens and also try moving the QT file created from the show to a new project to see if that plays back without issue.
    Bill Paris
