[Carsten Orlt] ” but in my case it actually takes away RT performance. Some RT effects that play (either preview or unlimited) with external monitoring off, do not play with external monitoring on (through the ioHD).
Is this normal behaviour or caused by the ‘slowness’ of the MacBook Pro?”
That’s a very good point. It does take some processing to play out real time video through any capture card device. It’s just the nature of the game as the video signal that goes out of FCP takes more horsepower as the video color space, frames, audio, everything must be accurate and in sync when displaying on an external monitors or when being sent to devices. This requires power. When displaying just through FCP and no capture card, accuracy is not as much of a concern, especiialy when it comes to temporal resolution.
Yes, I use both a MacPro and MacBook Pro. I use the ioHD mainly on my laptop, though. The Macpro is a work horse, but I can’t bring it with me in the field when we’re out shooting, so I use the laptop. Yes, it’s a big speed boost, but I have 8 3.0 Ghz processors and a raid that sustains close to 400MB/sec. I would expect it to go faster just by the math alone. The MBP Express card is a limited bandwidth bus, you can only push so much data through it at a finite speed. The multilane PCIe structure within the MacPro is much more flexible and much faster when combining the throughput of several drives. In my case, my raid has 8 drives which is why I see the speed.
It really depends on your workflow and what you need. I need both so I use both.
Back in the ‘old days’ of editing on a dual 2.0 G5, turning off the internal display (mirror on desktop) allowed more rt editing of uncompressed HD. Perhaps you should try that as it may help you. Display only externally and not internally to FCP.
Hope that helps a bit.
Jeremy
