Activity Forums Apple Final Cut Pro Legacy RT in with blackmagic
  • RT in with blackmagic
    Posted by Levan Bakhia on December 13, 2005 at 8:24 am
    When in sequence setting (in final cut) I use blackmagic in compressor (quicktime video settings) in my RT extreme menu, all the setting disappear, I alno get option “Play base layer only”. and as I understand this means that I don’t get the real time in Final Cut Pro. So why is that?
    And also can anyone tell me difference between:
    Blackmagic 10 bit (DV10) and Blackmagic RGB 10 bit
    or
    Blackmagic 8 bit (2Vuy) and 8 bit (DV00)
    is blackmagic RGB 10 bit better than uncompressed 10bit 4:2:2? Please consider, that I shoot on 35mm film, than telecine it at 1920X1080 resolution, and after editing I sometimes print back to film. So is blackmagic good codec for using this way?
    Oh, and I have blackmagic HD pro (single link).
    Nils replied 20 years, 8 months ago 2 Members · 1 Reply
  • Nils
    December 14, 2005 at 11:12 am
    To take advantage of RT effects in FCP, capture and edit using apple’s “uncompressed 10bit 4:2:2”. Also set effects handling of 10-bit to FCP
    This is as advised in the decklink manuals. In fact their Easy Setup’s select apple’s 10-bit codec.
    Apparently the “Blackmagic Uncompressed 10-bit” codec works better than apple’s as an output module for 16-bit projects in after effects. The drawback is there are no RT effects.
    Nils
    Sydney, Australia
