Activity Forums Apple Final Cut Pro Legacy RT drop menu missing options
  • RT drop menu missing options
    Posted by Ryanservant on August 12, 2005 at 2:54 am
    I am trying to do a quick multiclip edit and everything is in place except for the fact that on my RT drop down menu on my timeline I have no option to select for multiclip playback. All it says is ” Play base layer only, use playback seetings, or full quality. Right now I have my multiclip in my timeline, double clicked it so it goes into the viewer. I see all angles and the top left angle is selected. As soon as I hit play it comes to whatevr clip i have selceted. This happens even though I have open selected in my viewer and no matter if I play it from the viewer or the timeline..it always goes from my six angles to one as soon as i hit play. When I stop it from playing it goes back to showing me all the angles. My clips are HDV and I am editing on my g4 powerbook.
    thanks for the help guys..im going nuts trying to research this stupid problem, im sure im one check mark away from it working.
    Ryan
    G5
    xserve 2.5 TB
    FCP HD
    2 gigs ram
    Used to be Kona Hd…Now its Decklink HD pro
    Ryan Servant
    AirSeaLand Productions
    http://www.airsealand.com
    718-626-2646
    Ryanservant replied 21 years, 1 month ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 13, 2005 at 1:56 am
    Don’t see the option at all, or is it greyed out? (and you have turned on the “Open” option in the canvas or viewer?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ryanservant
    August 22, 2005 at 9:22 pm
    I dont see it at all….and yes I have the thing to open….is a powerbook too slow to do multiclip with HDV?
    thanks Jerry
    G5
    xserve 2.5 TB
    FCP HD
    2 gigs ram
    Ryan Servant
    718-626-2646
