  • Posted by Dan Lachevre on September 10, 2007 at 8:26 pm
    We’ve just upgraded to VSN 6 and for some reason I can’t seem to get RT disolves working anymore in a PAL Photojpg sequence. I’m on a Quad G5 is that the problem?
    The default Photojpg 320 x 240 seq set works but as soon as I use the full size it removes all my RT setting on the motion tab.’
    All the footage works ok just the disovles have the problem.
    Any ideas?
    Jeremy Garchow replied 19 years ago 2 Members · 5 Replies
  • Jeremy Garchow
    September 10, 2007 at 8:55 pm
    What’s VSN 6?
  • Dan Lachevre
    September 10, 2007 at 10:30 pm
    Final Cut Pro Version 6
  • Jeremy Garchow
    September 11, 2007 at 1:41 am
    If you are saying that you have moved to Photo-JPEG @ full resolution, there’s no rt that’s enabled in that codec/frame size/resolution.
    Jeremy
  • Dan Lachevre
    September 11, 2007 at 4:59 am
    Thanks Jeremy. Don’t know what I was thinking.
  • Jeremy Garchow
    September 11, 2007 at 1:22 pm
    What format is your footage?
