Activity Forums Apple Final Cut Pro Legacy rt. click mouse? Track ball? what do the pros use?
  • rt. click mouse? Track ball? what do the pros use?
    Posted by Zack Hill on May 20, 2007 at 9:11 pm
    I started editing and computering with a single click mouse right handed. My shoulder started to hurt. I bought a right click mouse and got good at using my left hand, which I really like for use of keyboard control in FCP (jkl;) but, my left shoulder is starting to hurt.
    What do you guys use? Toggles? track ball? mouse? any hints would be appreciated!
    thanks,
    jesus
    http://www.vayacongringos.com
    G5 4gigs FCP 5.1.2
    David Bogie replied 19 years, 4 months ago 12 Members · 11 Replies
  • 11 Replies
  • Jerry Hofmann
    May 20, 2007 at 10:59 pm
    Read about ergonomically working with mice.
    I use one without pain.
    Some people like trackballs, but I don’t. Others like Wacom tablets, I think it has it’s place for sure.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tom Matthies
    May 20, 2007 at 11:09 pm
    I use a Wacom Graphire tablet to largely replace my mouse. I find that it’s a lot faster (to me) than a mouse and I can edit all day without any serious physical side effects. Plus it’s handy in programs like Photoshop as well. My 2
  • Jeremy Garchow
    May 20, 2007 at 11:10 pm
    I use a Wacom and it has cleared up a lot of my repetitive task pains. It works very well and once you get used to it, is really nice. Also, mapping the keypad on both sides of it really helps as well.
    Also, if you use AE/Motion/photoshop for any kind of masking work the tablet is really really sweet for this.
    Jeremy
  • John Davidson
    May 20, 2007 at 11:20 pm
    I use a logitech media play mouse with about 12 buttons that I mapped using a program called usb overdrive. It takes quite a few keystrokes out of the way like: snapping on/off, next edit, volume up/down, etc. I find that, for me, it works best to use the mouse with fcp, Maya, and the majority of Apple apps.
    For After Effects, Photoshop, Illustrator and the adobe family, I use a wacom intuos tablet.
    Ultimately you’ll have to try each setup out for a day and see what works best for you.
    Good luck!
    John Davidson____ writer | producer | director____https://www.magicfeather.tv
  • Ben Oliver
    May 20, 2007 at 11:24 pm
    i wear out mighty mouses like i do socks after running a marathon.
    just make sure you have a good chair, and perhaps consult a dr. I had horrible carpal tunnel esque tendenitis, but i corrected my posture, and it’s all gone now.
  • Debe
    May 20, 2007 at 11:32 pm
    Put me in the Wacom tablet group.
    debe
  • Larry Asbell
    May 21, 2007 at 1:26 am
    I went through 5 years of wrist and shoulder pain from bad editing ergonomics. But the last 10+ years have been much better with these helps:
    I too learned to mouse left handed and switch frequently.
    I keep the height of my keyboard/mouse surface LOW. For me about that’s about 22″ off the floor. When I was freelancing in rooms with higher editing desks I would bring a “Herman Miller scooter” so I always had a comfortable height.
    I did a few years of accupuncture and massage therapy which both helped. I learned and do a morning stretch routine from a great book by Bob Anderson called “Stretching.” But the therapy that I strongly recommend anyone with back or shoulder tension look into, can be found by Googling “self massage tennis ball.” A massage therapist recommended it to me as a between appointment tune up. Not a great business move for her, because with it alone I’ve nipped in the bud every flare-up of back/shouder pain for the last ten years. If you like it and want to try something even better, Google “Theracane,” buy one for $35 and use it when you need to.
    Wishing you good health,
    – Larry Asbell
  • Stuart Simpson
    May 21, 2007 at 8:07 am
    Our suites all use Kensington Expert Mouse Pro’s – basically 4 button trackballs. Keyboard shortcuts are your friend for FCP though…
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Steve Radley
    May 21, 2007 at 12:47 pm
    Mighty Mouse. I find that as long as my wrists are supported, either by a gel pad or the desk, it doesn’t matter what I use.
    Steve Radley
    Digitec
    Orlando, FL
    https://www.digitecinteractive.com
  • Pxlmvr
    May 21, 2007 at 1:00 pm
    Wacom Intuos 3. 4 button mouse, 5 including click wheel.
    Occasionally, after long periods of editing, my wrists will start to hurt a little. I usually change to using the stylus for a while. Also, as been said, keyboard shortcuts break up mouse usage.
